Home > Maintenance & Modifications > Following my service the garage reported these advisories…
AIJ 615
Evening all
So yeah had my RRS 2010 HSE serviced at an independent LR specialist garage whom have a pretty good reputation locally. Anyway paid £600 for a full service which includes a 50 point check up.
I was informed the following on the notes (see attached) and then the garage contacted me earlier and asked if I wanted the RRS to be booked in for some follow up work in priority order. The exact message I got was:
“Hi my technician says that the first thing to sort out is the rear suspension arm and the front suspension arm. It might be better to do these at the same time as we have to carry out 4 wheel alignment every time we change an arm. The estimate for this is £996 inc VAT.”
Does this sound reasonable for the work and does it match the attached photo of advised issues ?
Post #630151 Mon Jan 23 2023 6:31pm
riverblanche
first off I thought the service was on the high side Question then noticed the job sheet states they have
"checked and topped up the axles, transfer box and gearbox"
are you sure they have done this Question if so the cost might not be that much out
I would want confirmation of what Exactly they will be changing and with what type of bush, upper, lower, bush and arm wise, if its both sides front and rear and alignment then it does sound in the right ball park, I would get another quote (like for like) if spending that amount,
Ask how they checked the gearbox level and did they add any fluid, depending on that answer might help you decide. Whistle
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #630152 Mon Jan 23 2023 8:04pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Wow that was an expensive service
Post #630160 Mon Jan 23 2023 9:10pm
AIJ 615
You think ?
I did enquire and a Landrover main dealer garage wanted like £850 for a service. This garage was a local independant Landrover specialist garage. They do use genuine Landrover parts for service.
I just got confuse Cause the advisory notes mentioned the bushes and yet the text from them talks about arms for front and back. ???
Post #630166 Mon Jan 23 2023 11:07pm
riverblanche wrote:
Little curious on that one as well, as L/R specifically say the filler plugs on the transfer box and diffs are not level plugs, if changing the oils you fill with a specific measured amount of oil, unless there is a leak how did they determine the levels were low and possibly need topping up.
Post #630167 Tue Jan 24 2023 12:57am
AIJ 615
Does this sound about right ?
So the LR specialist garage have quoted me the following to get some of the advisories from the recent service I had done.
Post #630371 Sat Jan 28 2023 6:48pm
riverblanche
you still need to know What exactly they plan on doing before you will know if the price is reasonable or not Question
Just talking about the front lower arm, is it a complete new arm? all bushes replaced in old arm? just rear bush replaced in the arm?
Bushes OEM or poly type?
I have just replaced an EGR valve, they vary from £24 -£280 all for a new valve Shocked
2 prices I had from Indep for fitting an OEM valeo valve was £380 and £480
You need to know what work is planned.
Post #630376 Sat Jan 28 2023 8:25pm
AIJ 615
Cheers for this, I will ask for more specifics detail relating to this. I assume for that price it would be full arms but again need them to reassure me of this
I presume that’s what’s you mean
Post #630377 Sat Jan 28 2023 8:31pm
Lrstaylor
I'm so glad I do my own repairs seems even the indies are over charging for repairs now days. I did both front lower control arms plus an inner cv boot on 1 side for less than £165 in parts on my drive. OK on our D3 but basically the same job as its the same parts. Soon todo o/s front lower on my rrs sc.
Post #630393 Sat Jan 28 2023 11:38pm
AIJ 615
Update
So yeah as advised by you good folk I’d gone back to the garage and asked what exactly was I getting for the price quoted and the Response was this ,
“No it is just the 2 arms. 1 rear upper and 1 front lower. The upper arm is £120 and the front arm is £160. 5 hours workshop time at £90/ph and 4 wheel alignment £90. All prices plus VAT. It is not a simple job to replace the rear arm. It does not include the D bushes these can be done separately. The bushes are already in the arms best OEM. Just need it for the day for this work.”
What you guys think ? Reasonable
I did think they only use genuine LR parts but for that price I don’t think they are genuine ?
Alan
Post #630426 Mon Jan 30 2023 11:16am
A1GSS
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
I was recently quoted £280 parts (ex vat) plus 3 hours labour to change both lower fronts (local Indie, non-LR but OEM parts). So it doesn't seem out of whack.
Four wheel alignment definitely needed.
In your shoes I'd maybe consider having both L&R done at the same time. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #630428 Mon Jan 30 2023 12:28pm
Lrstaylor
I know they have to make money but I'm sure I did both my front lower arms plus inner cv boot in less time than that on the floor. It's much easier on a ramp .
I also agree about doing both front lower armsxat the same time as the previous owner of my sport only did 1 side so I'm doing the other side my self once the weather improves.
Have you watched a YouTube video on replacing the arms?? Some places have them off and replaced in under an hour
Post #630429 Mon Jan 30 2023 1:18pm
Disco_Mikey
Under an hour? I'm going to assume they are a garage in "not Scotland" Laughing
Post #630447 Mon Jan 30 2023 8:30pm
I really would like to see someone replace a front lower arm in under a hour, if the main pivot bolts are rusted solid in the bushes and they have to cut them out with a hacksaw or reciprocal saw. Sometimes you may be lucky and they are not seized other times not so especially on older vehicles, which is why it can take a lot longer.
Post #630448 Mon Jan 30 2023 8:31pm
Lrstaylor
I got lucky with mine, nothing siezed I'm hoping I get lucky again when I do our new to us D3cand my off side on the rrs. What's the chances? Slim I know.
Post #630449 Mon Jan 30 2023 8:34pm
