Home > Technical > 2012 Headlight dip/high beam mismatch. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4977 |
No you can not adjust Main Beam and Dip Beam separately. Adaptive just means the beam moves to suit driving conditions i.e if turn a corner the beam moves to illuminate more of the road based on the direction you turn the steering wheel as it is in part controlled by the steering wheel movement, however I'm sure someone will be along to give you chapter and verse on the subject shortly. It is not the same as cornering lamps though they just illuminate the kerb when cornering.
Sat Jan 28 2023 11:13pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Sounds like the headlight module has possibly died if they were aimed into the trees initially. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Jan 29 2023 8:07am |
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 49 |
Well.....
Sun Jan 29 2023 5:55pm |
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 38 |
Land Rover always seem to have high beam pointing to the stars… |
Sun Jan 29 2023 6:57pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4952 |
your not the first to complain.
Sun Jan 29 2023 8:00pm |
The main beams are quite good once set properly. Good range and spread.
Wed Feb 08 2023 12:35am |
Sounds normal
Wed Feb 08 2023 6:35am |
Poked about a bit further.
Tue Feb 21 2023 4:18pm |
Just had a look at a MY11 & MY13 sales brochure and adaptive lighting was a option on all variant except the 5.0L A/B which it was standard on, so you may not have it, the cornering lamps were standard on all variants, but obviously that is a different thing to the adaptive lighting.
Tue Feb 21 2023 8:10pm |
Thanks for that Col.
Tue Feb 21 2023 10:28pm |
Anyone know how to change the dip for driving on the right?
Wed Feb 22 2023 12:57am |
You don't, the design of the lens/beam pattern makes it adjustment free.
Wed Feb 22 2023 3:46am |
I believe it’s called a flat beam. (No kick up on one side )
Wed Feb 22 2023 4:22am |
Can always get 2010/2011 headlights with the switch and better light pattern. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Feb 22 2023 5:11am |
