Home > Technical > 2012 Headlight dip/high beam mismatch. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Should have this Icon come up when vehicle doing system check if AFS fitted, if fault with the system it should continually flash I think.
Sat Feb 25 2023 9:17am |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
your correct col
Sat Feb 25 2023 9:24am |
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 49 |
Andy. Your suggestions 1 and 2 are very wise, but rural area and unfortunately not many sports around otherwise I would have tried this already.. Heaps of L322s though Second hand headlight to compare is a good idea. Better to mess with a spare too. What's AFS? As to a garage setting lights . I am more than capable of knowing where my headlights should be set and doing it. Most drivers aren't judging by the cock-eyed things I meet. Main beams should be set first for optimum light on the road and range. If the dips are not separate then they just have to be accepted where they end up. This is seldom a problem if the makers design them properly with the right angular difference between the two. A very slight compromise tweak is possible if required. MOT a couple of days ago. I set the dips back to where I would expect them to be on the road, the night before. Asked friendly MOT chap what the dips looked like and he said bang on. Thankyou. Mains are halfway up the trees. Someone mentioned bulbs. Haven't changed them. They both look fresh and straight, though it would only take a slight offset to seriously affect the cutoff due to the very short distance between the filament and the shield. I'll pull the headlights out again and have a longer look at the shields. Its a pity the projector assembly won't come out the access hole for a better look. Thanks to all Alan Series 3 109 Classic 2-door 101FC GS Three P38 4.6L RRS mk1 2012 |
Sun Feb 26 2023 12:30am |
These are the best I can do at the min. as it's 25 degrees and bright sunshine, however this is what I get with mine looking through the windscreen in the garage, car is about a metre from the garage door, obviously first picture dip, second main beam.
Sun Feb 26 2023 1:26am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
Ok. So your dip beams have been reset. You are back to square/page 1.
Sun Feb 26 2023 2:45am |
Ok Andy.
Mon Feb 27 2023 4:45pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
The halogens are termed "fill in beams" and are supposedly intended to help cover bits of the pattern that the xenons don't cover properly.
Mon Feb 27 2023 6:34pm |
The later disco's and Jag's don't even have main beam halogens, so that's how important landrover considered they were,
Mon Feb 27 2023 6:51pm |
Well.......
Tue Feb 28 2023 1:19am |
