Home > Maintenance & Modifications > Remapping !
Page 3 of 5 <12345>
AIJ 615
⬆️⬆️⬆️ You guys agree with that, is it normal ? ⬆️⬆️⬆️
Post #630235 Wed Jan 25 2023 5:37pm
I had both my TDV8 and 5.0L and neither had a fault come up, however they may be correct as you can actually reset the adaption values using the Gap diag. tool as well, which then in theory will learn new parameter based on your driving style etc. not sure how long or the mileage it will take to learn them though, not long I wouldn't think. Might be worth just driving it around and see If it sorts itself out.
This looks like the code shown in you're gallery.
Post #630240 Wed Jan 25 2023 8:38pm
Disco_Mikey
We had this once with a remap we carried out, turned out there was a faulty injector which wasn't apparent beforehand
It could also be that they are asking too much from the injectors, but I'd assume they've mapped 3.0's before...
Post #630241 Wed Jan 25 2023 8:40pm
AIJ 615
Thanks guys.
Update:
So after I read and reset the codes I left it an hour and took the RRS back on a stretch of dual carriageway and again as soon as I hit just under 70mph the ‘Engine Systems Fault’ error code came up.
I’ve informed the garage and they gonna have a look at it for me. The power seem really good it’s just the fault occurs once it hits 70mph. Not sure if the actual remap or the EGR remap is causing it as had them all done together earlier
Post #630243 Wed Jan 25 2023 9:01pm
AIJ 615
Garage have advised to take her on a decent run so I’m going to reset the error code and keep her under 70mph as so not to trigger the error fault and I’m going to take her 50 mile trip as I’ve got to go out anyway
Hopefully the theory behind it is the car relearns itself these new perimeters ???
Fingers crossed
Al
Post #630248 Thu Jan 26 2023 8:15am
TheWojtek
Forever?
AIJ 615 wrote:
as so not to trigger the error fault. I’m going to take her 50 mile trip
I am afraid this will not fix it. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #630249 Thu Jan 26 2023 8:22am
AIJ 615
Not forever just to to let it retrain itself on the new parameters on this 50 mile trip ????
Why don’t you think this will work - am I being ‘fibbed’ off by the garage ?
Alan
Post #630250 Thu Jan 26 2023 8:30am
TheWojtek
No, I believe they uploaded a new map and more or less called it a day while your injectors are maxing out. Was it a custom dyno tune or a quick reflash? Regards etc.,
Wojtek
Post #630261 Thu Jan 26 2023 10:32am
AIJ 615
Hi, wasn’t a custom remap but rather a generic one for a RRS 2010
So you have heard of the EVM needing to familiar itself with the new remapping perimeters?
Al
Post #630262 Thu Jan 26 2023 10:39am
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Disco_Mikey wrote:
Don't use Celtic Tuning...
Not sure if thats who you are referring to, but that webpage looks awfully familiar
It should also be said, that a bad remap will also cause engine damage, just for balance and fairness Wink
That is a celtic gains screenshot. I would see who your local company use as a master. Bet its them.
Honestly I have had NO issues with my alive map. Been absolutely fantastic in fact.
Post #630263 Thu Jan 26 2023 10:54am
I think the OP should consider what Disco-Mikey has said and consider that the remap has just highlighted an issue that wasn't apparent previously. Although the excerpt that Col put up does show one cause of the error message being a software flash fault.
Trying to get the remapping company to sort it is going to be "fun". The best you can hope for is a reset to standard and perhaps some money back. Or they'll just say "not out problem, mate" and leave you to fight them. 2012 SDV6 - it's missing a couple of cylinders
Post #630265 Thu Jan 26 2023 11:10am
Bertbuckie
Yes I would be inclined to agree.
Unsure of a bad flash tbh... they are all checksum checked etc and a bad flash usually means non-start ( unless a crap map )
Post #630267 Thu Jan 26 2023 11:16am
TheWojtek
No, that's not going to happen. The remap requests a certain amount of fuel to be delivered to the cylinders and (most probably) the injectors are not up to the job. You may hope they will unclog themselves with the increased amount of fuel thrown at them (unlikely), you may try to unclog them with an injector cleaning fuel additive (again, rather unlikely).
If the garage didn't measure the injector corrections (degradation of the actual injector performance from the rated value) that the engine has worked out throughout its life, and didn't adjust the map accordingly, you have been uploaded a map assuming all injectors work at 100% rated flow. As we all are aware, this never happens, they degrade with time.
That's why you are running way too lean in full-throttle scenarios and that's why you get the errors.
Now the good and bad news:
- the bad news is your map may be maxing out the injectors. They can not deliver what is requested from them. An injector diagnostics and replacement may be in order.
- the good news is a serious degradation takes serious time and kilometers. Maybe - but this is a maybe - your system needs a calibration reset and some driving. In which case the procedure suggested by the garage may work.
Point is, this should've already happened. If you (or the garage) reset the calibration, this takes a couple of hours for the ECU to work it out properly. In this case, it may happen your corrections are already set again, but they exceed what the injectors can deliver. Back to "bad news" square.
Still, this is a generic map and while you can feel the difference, you have no idea how the power increase has been realised. If it is a simple "crank the boost and throw some fuel at it" (as in: "not customized to the particular vehicle, preferably on a dyno"), it's not a good remap.
Technically it's not a remap at all, since nobody "mapped your engine again", it's a straight reflash and they are risky for reasons laid above. Regards etc.,
Wojtek
Post #630268 Thu Jan 26 2023 11:17am
Bertbuckie
I see a lot of this generic and RR map debate. Most ecu's now cannot be live tuned. The ECU he has in particular ( iirc its an edc17cp11 ) is a bench only job. The only way to live tune so to speak is many many runs and removals to fine tweak it. I cant think of any mapping company that does this for all cars, hence a specialist will have spent a bit more time I would imagine on a certain engine/brand.
Post #630269 Thu Jan 26 2023 11:20am
TheWojtek
Yes, the Bosch ECU is bench only, however I believe the reflashing should be preceded with some diagnostics (injectors, boost pressure), results of which should be taken into account and the map tweaked before uploading. Then test drive/dyno run with live data monitoring, back on the bench, adjust the map, test drive... That's why remaps costs so much! Regards etc.,
Wojtek
Post #630270 Thu Jan 26 2023 11:29am
Page 3 of 5 <12345>
