![]() | Home > General > New Battery |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
Exide is all we use |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
Exide is in it just now. Reason for changing makes is that battery is on year 4, but only a 3 year warranty |
The rest of them are |
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 ![]() ![]() ![]() |
I run a Bosch S5 on my TDV8 it seems happy enough after 3 years. I don't drive the car every day. |
I've used Tanya a few times,, used the enduroline battery twice on the RRS,,, lasted less than 4 years first time and less than 3 years last time. Went with Tanya again as there service and price are good,, but went with Yuasa this time with 5 year guarantee,,, and not much more than the enduroline. 2010 RRS, TDV8
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I fitted a Varta AGM from Tanya prior to shipping car to NZ, Over six years now and still going strong and starts first time, although low battery warning does flash up occasionaly now.
Forgot to check if you had answered, & got my order in today before they closed. Went for Enduroline ![]() ![]() |
Running a Varta AGM as well, I think it’s a G14 silver dynamic. No issues with over two years of use. Volt meter still showing 12.8v each morning. Used it in -18° to +35°, runs the timed heat/vent twice daily, never any starting issues. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Yeah, it is the G14 I fitted as well, not the cheapest but as said been good for six years and still going strong, wouldn't bother fitting anything else.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
It's worth remembering that a battery can show 12.7V (fully charged) but have a low charge capacity. The CCA of the battery decreases over time so a new 850A CCA might be down to 500A (or worse) after a few years. Recently had a new battery fitted because even though it showed c.12.7V, the CCA was well down. 2012 SDV6 - it's missing a couple of cylinders
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I've had a Tayna battery on my X5 for nearly 5yrs no trouble. The Range Rover (same type) has a Duracell battery that's been on 4yrs but is ok. Gone are the days when you could pop the small caps off and top them up..
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
My TDV8 only goes on very short trips (2-11km) so I have to use my CTEK several times a week. My current battery has lasted 7 years.
