Home > General > New Battery |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Exide is all we use |
Thu Jan 05 2023 12:22pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Exide is in it just now. Reason for changing makes is that battery is on year 4, but only a 3 year warranty Enduroline & Bosch which was my other thought has 5 year warranty. Car is not being changed any time soon
Thu Jan 05 2023 3:29pm |
The rest of them are
Thu Jan 05 2023 4:26pm |
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 |
I run a Bosch S5 on my TDV8 it seems happy enough after 3 years. I don't drive the car every day. |
Thu Jan 05 2023 6:18pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I've used Tanya a few times,, used the enduroline battery twice on the RRS,,, lasted less than 4 years first time and less than 3 years last time. Went with Tanya again as there service and price are good,, but went with Yuasa this time with 5 year guarantee,,, and not much more than the enduroline. 2010 RRS, TDV8
Thu Jan 05 2023 7:17pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
I fitted a Varta AGM from Tanya prior to shipping car to NZ, Over six years now and still going strong and starts first time, although low battery warning does flash up occasionaly now.
Thu Jan 05 2023 7:31pm |
Forgot to check if you had answered, & got my order in today before they closed. Went for Enduroline , well just have to see how it goes. Was pretty with Exide with just being out of 3 year warranty. I use the Ctek a lot as I have the comfort connector just inside the front valance. Its an instinctive thing just to connect it up, so the battery is never depleted even though the car is not used much. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
Thu Jan 05 2023 8:57pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Running a Varta AGM as well, I think it’s a G14 silver dynamic. No issues with over two years of use. Volt meter still showing 12.8v each morning. Used it in -18° to +35°, runs the timed heat/vent twice daily, never any starting issues. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Jan 06 2023 7:22am |
Yeah, it is the G14 I fitted as well, not the cheapest but as said been good for six years and still going strong, wouldn't bother fitting anything else.
Fri Jan 06 2023 7:30am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
It's worth remembering that a battery can show 12.7V (fully charged) but have a low charge capacity. The CCA of the battery decreases over time so a new 850A CCA might be down to 500A (or worse) after a few years. Recently had a new battery fitted because even though it showed c.12.7V, the CCA was well down. 2012 SDV6 - it's missing a couple of cylinders
Fri Jan 06 2023 10:27am |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
I've had a Tayna battery on my X5 for nearly 5yrs no trouble. The Range Rover (same type) has a Duracell battery that's been on 4yrs but is ok. Gone are the days when you could pop the small caps off and top them up..
Sat Jan 07 2023 6:06am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 402 |
My TDV8 only goes on very short trips (2-11km) so I have to use my CTEK several times a week. My current battery has lasted 7 years.
Sat Jan 07 2023 12:56pm |
