![]() | Home > Technical > Steering wheel vibration when braking |
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
I’d check the track rods for play 2015 RRS DIESEL HYBRID |
giacomo.m Member Since: 04 May 2016 Location: Roma Posts: 11 ![]() ![]() |
Thank you 3hcp
I had that on BMW X3 turned out to be discs which I bought off eBay and assumed were ok but weren’t 2015 RRS DIESEL HYBRID |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Have you had a 4x wheel tracking done? Barrie.
What is it ?
https://www.ms-autocare.co.uk/hunter-4-wheel-alignment
Ah ok,
Have you checked the tyres for feathering,first thing to do is swap front wheels for rear & vice versa & see if that makes any difference,also are you getting any road noise like a wheel bearing as gone.? Andy.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Warpped brake discs possibly. Need to check their run-outs |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
Mine was and has been front rotors, like clock work they get replaced every 2 years regardless of miles on the car. The good news is it started while car was under warranty and it’s back on Dec 4 to the dealer for another set. I’ve never replaced brakes on any other car, truck, etc like this before. I’ve gone from 13,000 to 5,000 miles a year same issue.
Hi all,update
There’s also the issue of brake pads, especially non original cheap ones. These cars were never made to run on a cheap budget, unfortunately |
I’ve balanced 000’s of wheels on Rangerovers & never had a problem,even using the cheaper end Chinese balancers. Andy.
Thank you erickwan, i mounted ATE front disc brakes and pads..... maybe the Brembos are better ? Giacomo |
