Home > Technical > Steering wheel vibration when braking
giacomo.m
Italy
Hi all,
I have a 2013 RRS with very slight steering wheel vibration at 90/100 Km/h ( no pedal vibration ) when braking from higher speeds.
I have the wheel balanced- new front discs and pads ( Ate ) - new anti-roll bar bushes on lower front control arm,- new front stabilzer bar bushes - new left front wheel hub bearing kit.
I don't know what to do anymore, can you help me ?
thank you
Giacomo
Post #628543 Thu Nov 24 2022 3:12pm
3hcp
I’d check the track rods for play 2015 RRS DIESEL HYBRID
Post #628547 Thu Nov 24 2022 5:43pm
giacomo.m
Italy
Thank you 3hcp
but no play on tie rod end and spindle connecting rod....
Giacomo
Post #628548 Thu Nov 24 2022 5:58pm
3hcp
I had that on BMW X3 turned out to be discs which I bought off eBay and assumed were ok but weren’t 2015 RRS DIESEL HYBRID
Post #628554 Thu Nov 24 2022 8:35pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Have you had a 4x wheel tracking done? Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #628566 Fri Nov 25 2022 7:19am
giacomo.m
Italy
What is it ?
Giacomo
Post #628567 Fri Nov 25 2022 7:22am
BJH1959
https://www.ms-autocare.co.uk/hunter-4-wheel-alignment
https://pro-align.co.uk/product/hunter-elite-td/
A summary of what it is. Barrie.
Post #628568 Fri Nov 25 2022 8:06am
giacomo.m
Italy
Ah ok,
I had a full alignment done
Giacomo
Post #628573 Fri Nov 25 2022 1:17pm
Tyrefitter
Have you checked the tyres for feathering,first thing to do is swap front wheels for rear & vice versa & see if that makes any difference,also are you getting any road noise like a wheel bearing as gone.? Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #628577 Fri Nov 25 2022 2:46pm
erickwan
Malaysia
Warpped brake discs possibly. Need to check their run-outs
Post #628639 Mon Nov 28 2022 1:21am
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Mine was and has been front rotors, like clock work they get replaced every 2 years regardless of miles on the car. The good news is it started while car was under warranty and it’s back on Dec 4 to the dealer for another set. I’ve never replaced brakes on any other car, truck, etc like this before. I’ve gone from 13,000 to 5,000 miles a year same issue.
They tried the “it’s how I drive”, which I guess could be. However all my car records don’t have this pattern and had a chuckle at the service manager a few years ago.
My guess is under speced brakes for the weight of the vehicle. My XC90 lasted for 80,000 miles no brakes. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #628698 Tue Nov 29 2022 2:47pm
giacomo.m
Italy
Hi all,update
swapped the front wheels for rear & vice versa, checked the run- outs of the front brake discs with a dial gauge, but the problem exists......
I seem to have read somewhere that the tires of these R.R.Sports require a particular Hunter balancing machine, it is true ?
Is there a Land Rover technical bulletin on this ?
could the steering rack also be the cause ?
thank you
Giacomo
Post #634337 Mon Jul 17 2023 11:11am
erickwan
Malaysia
There’s also the issue of brake pads, especially non original cheap ones. These cars were never made to run on a cheap budget, unfortunately
Post #634405 Thu Jul 20 2023 3:56am
Tyrefitter
I’ve balanced 000’s of wheels on Rangerovers & never had a problem,even using the cheaper end Chinese balancers. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #634408 Thu Jul 20 2023 5:24am
giacomo.m
Italy
Thank you erickwan,
i mounted ATE front disc brakes and pads.....
maybe the Brembos are better ?
Giacomo
Post #634410 Thu Jul 20 2023 6:30am
