![]() | Home > Technical > Steering wheel vibration when braking |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
Have you checked all control arm bushings (front and rear). 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
giacomo.m Member Since: 04 May 2016 Location: Roma Posts: 11 ![]() ![]() |
Front lower arms news,
Yes, essentially the tail wagging the dog. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Hi all, update
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
Check that the disc mounting screw isn't sticking out just a little bit. It needs to be either recessed in the hole, or flush. Even just a tiny fraction will mean that the wheels don't go on flush to the hub. The wheels will always be in balance when checked off the car, but you'll introduce some variation if your screw isn't flush when you mount them. |
Thank you Jonny CJ
