Home > Technical > Collapsible spacer for front diff (LR006011)
Kzwpoas1
Hello,
Does anyone know the part number or where I can get a collapsible/crushable spacer for the pinion shaft in the front diff, LR006011 or TAG500063 for RRS L320 2009 or Disco 3, 2009?
This part is proving to be very elusive. Can you hammer out and reuse the old spacer, if you mark the original position on the pinion shaft and nut? I understand the spacer offers up the correct preload bearing force. As I can't find anywhere the correct torque settings and backlash specs anywhere, although I am assuming it's between 0.008 to 0.012 of an inch but would rather get in bang on!
Any help and advice would be much appreciated.
Post #628479 Wed Nov 23 2022 2:22pm
erickwan
Malaysia
Can you even get internal parts for the LR diff, save for a few seals etc, according to LRCAT.
Post #628640 Mon Nov 28 2022 1:36am
