Kzwpoas1
Collapsible spacer for front diff (LR006011) | |
Hello,
Does anyone know the part number or where I can get a collapsible/crushable spacer for the pinion shaft in the front diff, LR006011 or TAG500063 for RRS L320 2009 or Disco 3, 2009?
This part is proving to be very elusive. Can you hammer out and reuse the old spacer, if you mark the original position on the pinion shaft and nut? I understand the spacer offers up the correct preload bearing force. As I can't find anywhere the correct torque settings and backlash specs anywhere, although I am assuming it's between 0.008 to 0.012 of an inch but would rather get in bang on!
Any help and advice would be much appreciated.
Wed Nov 23 2022 2:22pm |
