![]() | Home > Technical > RRS 2021 SC OIL LEAK |
drexal Member Since: 17 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hi guys,
Thanks so much Andy K 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
When you check the oil level via the menu, what message are you getting from the readout?. Have never put a drop of oil in my S/C between services in nearly ten years. Might be just a faulty oil level sensor.
Hey Col,
Hi, as I don't do many miles these day's probably 3-4k and after all this time as it's long bought and paid for and stand's me in at nothing now so no real logic in changing it, the way I look at it now £80k+ buys a lot of maintenance and at only $110.00 (£60.00) road tax no point |
Thats really good to hear, makes me feel better knowing your experience so far as i want to keep it as long as possible. Apart from the small oil leak previously this is kind of the first fault light i've had. Just read online:
Does mention this, something to do with evaps system I believe, also says NAS vehicles so not sure if same applies to U/K/Row vehicles. I suppose the logical thing is to check the cap is tight and sealing. |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
Not like the good ol days, if you leave the fuel cap off the FJ or EH you didn't know till someone pulled along side at the street lights and wound down the window and told ya ( fuel caps off mate) or you found out next fill, which could be weeks. |
"found out next fill, which could be weeks."
Yeah it was 138ci grey motor in the j or the 149ci updated Red motor that went for weeks . |
Fuel cap is to do with north American cars |
Hi guys,
The electronic dipstick is the same as a physical one - you are basically seeing the bit of the dipstick between the top and bottom marks, so if the electronic version shows half way then that is the same as halfway between top and bottom marks on a physical dipstick - or about half a litre of oil. Most people would not top up if the level is midway between the marks on a physical dipstick, but they would perhaps monitor the levels more regularly to ensure there isn't a leak.
Thanks for your time RRSTDV8, and for explaining, i just found these 3x attachments that apparently allow you to check the oil level cold, with out having to take it for a drive and get it warm and then wait for 12mins to check it. So will try to see if this works for me so i can keep checking it regularly. And next time i get a job i will buy some axle stands so i can get uneath and finally clean all the old oil away so i can spot if i have a new leak more easerly. Thanks for tip on over filling. Hoping once the IID tool shows up it will make my LR owner experience slightly more relaxed.
