Home > Technical > RRS 2021 SC OIL LEAK |
drexal Member Since: 17 Dec 2019 Location: london Posts: 114 |
Hi guys,
Thu Nov 10 2022 2:18pm |
Thanks so much Andy K 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
Thu Nov 10 2022 3:08pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
When you check the oil level via the menu, what message are you getting from the readout?. Have never put a drop of oil in my S/C between services in nearly ten years. Might be just a faulty oil level sensor.
Thu Nov 10 2022 8:27pm |
Hey Col,
Sat Nov 12 2022 6:35pm |
Hi, as I don't do many miles these day's probably 3-4k and after all this time as it's long bought and paid for and stand's me in at nothing now so no real logic in changing it, the way I look at it now £80k+ buys a lot of maintenance and at only $110.00 (£60.00) road tax no point don't have slightest inclination in buying a RRS2 or 3 for that matter either, least of all a oil burner one. Only warning light I've had appear on the car was for the TPMS and that disappeared by it's self. Apart from service items and brakes, tyres etc. which would be normal on any car, it's had some of the usual stuff like lower front arms, rear door lock and a few other minor bits and pieces but nothing much, probably tempting fate now, but never had any issues with the engine whatsoever.
Sat Nov 12 2022 9:14pm |
Thats really good to hear, makes me feel better knowing your experience so far as i want to keep it as long as possible. Apart from the small oil leak previously this is kind of the first fault light i've had. Just read online:
Sat Nov 12 2022 11:21pm |
Does mention this, something to do with evaps system I believe, also says NAS vehicles so not sure if same applies to U/K/Row vehicles. I suppose the logical thing is to check the cap is tight and sealing.
Sun Nov 13 2022 12:21am |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
Not like the good ol days, if you leave the fuel cap off the FJ or EH you didn't know till someone pulled along side at the street lights and wound down the window and told ya ( fuel caps off mate) or you found out next fill, which could be weeks. |
Sun Nov 13 2022 2:14am |
"found out next fill, which could be weeks."
Sun Nov 13 2022 2:19am |
Yeah it was 138ci grey motor in the j or the 149ci updated Red motor that went for weeks . Sorry a bit of Aus banter |
Sun Nov 13 2022 5:40am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Fuel cap is to do with north American cars |
Sun Nov 13 2022 5:05pm |
Hi guys,
Mon Nov 14 2022 2:39pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
The electronic dipstick is the same as a physical one - you are basically seeing the bit of the dipstick between the top and bottom marks, so if the electronic version shows half way then that is the same as halfway between top and bottom marks on a physical dipstick - or about half a litre of oil. Most people would not top up if the level is midway between the marks on a physical dipstick, but they would perhaps monitor the levels more regularly to ensure there isn't a leak.
Mon Nov 14 2022 5:08pm |
Thanks for your time RRSTDV8, and for explaining, i just found these 3x attachments that apparently allow you to check the oil level cold, with out having to take it for a drive and get it warm and then wait for 12mins to check it. So will try to see if this works for me so i can keep checking it regularly. And next time i get a job i will buy some axle stands so i can get uneath and finally clean all the old oil away so i can spot if i have a new leak more easerly. Thanks for tip on over filling. Hoping once the IID tool shows up it will make my LR owner experience slightly more relaxed.
Mon Nov 14 2022 5:22pm |
