![]() | Home > Technical > RRS 2021 SC OIL LEAK |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I always check the oil level on mine first thing in the morning when the engine is cold from being stood over night, you can then do it from the drivers seat, and not bother with any of the rubbish about opening the bonnet etc, etc. If in doubt you could always read the owner's handbook, lists displayed messages and required quantity to top up and when. Unfortunately if it does have a faulty sensor there is no way of telling true quantity of oil unless you drain it and check the volume. You could always give it a oil change, on a 5.0L the quantity required for a oil and filter change is exactly 8 litres to refill then the full level will be spot on. A few litres of oil and filter is cheaper than a blown engine. I suppose the most logical thing to do first would be rectify any possible leak you may have in which case you may have to drain the oil anyway and go from there.
drexal Member Since: 17 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hey Col,
Thanks so much Col, for the advice on the poss MAF problem, i remember reading you suggested that in the previous forum going to try this out next week and will report back & thanks also for the advice on the wing mirror faults will look look at this to 🙌🏻 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
Hey Col,
Hi,
Thanks for super fast response as always 🙌🏻
