![]() | Home > Technical > MOT Failure - Shock Absorber; Movement Excessive |
Hiya, are you able to ask the tester for a more detailed explanation?. I take it you can’t see or feel anything amiss?.
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 43 ![]() ![]() ![]() |
Hi @steve
By excessive movement,it could be a worn bush,if that’s the case I would replace both sides at same time.Also I would use poly bushes as they are better & last longer. Andy.
Thanks lads.
