Home > Technical > MOT Failure - Shock Absorber; Movement Excessive
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
How is the test carried out for this and what exactly does it mean?
Is it that the shock itself needs to be replaced, or is it something like a worn bush?
Post #627843 Tue Nov 01 2022 9:54pm
Stevepd
Hiya, are you able to ask the tester for a more detailed explanation?. I take it you can’t see or feel anything amiss?.
Like you say it’s a bit vague…. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #627850 Wed Nov 02 2022 6:50am
pomistea
Hi @steve
No, I'm gonna phone MOT to ask for a clarification.
Post #627858 Wed Nov 02 2022 9:52am
Tyrefitter
By excessive movement,it could be a worn bush,if that’s the case I would replace both sides at same time.Also I would use poly bushes as they are better & last longer. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #627874 Wed Nov 02 2022 2:37pm
pomistea
Thanks lads.
It was difficult but I got a call from a mechanic at the test centre today.
Sound lad. He reckoned either the lower or top end must be loose.
He sounded a bit confused and all, and surprised at the vagueness.
He did also say the tester might have seen something when they do that test on the suspension, kinda bouncing it. Though I also thought they stopped doing that. In also though those tests came with specific thresholds and the results had figures, but he said no, tester discretion really.
Post #627918 Thu Nov 03 2022 7:28pm
