Home > Technical > MOT Failure - Shock Absorber; Movement Excessive |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Hiya, are you able to ask the tester for a more detailed explanation?. I take it you can’t see or feel anything amiss?.
Wed Nov 02 2022 6:50am |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 43 |
Hi @steve
Wed Nov 02 2022 9:52am |
By excessive movement,it could be a worn bush,if that’s the case I would replace both sides at same time.Also I would use poly bushes as they are better & last longer. Andy.
Wed Nov 02 2022 2:37pm |
Thanks lads.
Thu Nov 03 2022 7:28pm |
