![]() | Home > Maintenance & Modifications > Heavy white smoke and P0269 fault code |
beerguzzler Member Since: 01 Apr 2018 Location: swindon Posts: 28 ![]() ![]() ![]() |
Hi all, any help would be appreciated.
Thanks for your help, I'll give it a go at the weekend and let you know how I got on |
So, I had a look around the top of the engine to see if I can see any issues with the injectors and I can't see anything wrong. Started it up and ran it and lots of white smoke and running rough. I cleared the codes, checked to see if I could see any issues from the top of the engine and nothing. Checked codes again and it has changed now to P0275 Cylinder 5 Contribution/Balance.
So, update,
Oh that’s a bit unfortunate indeed. I suppose it’s bad luck the case has cracked after the engine was fitted and could the battery light be because of a failing battery and not the Alternator. Bushes are a wearable item and again just bad timing after spending a pile of cash. Are you confident in the indie?, think about T&S Norman not too far away if you have any doubts and make a decision. Keep us updated though. 2006 2.7 TDV6 HSE in Cairns Blue. |
