![]() | Home > Technical > Air vent stale odour NEW pollen carbon filter fitted |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
I've noticed the same on every car I've had,,, I think it's one of those things,,, condensate will appear in the system as it moves from cold to warm. Try putting a bomb through the system,, it's helps for a while. Euro car parts were selling them for a few quid a while ago. 2010 RRS, TDV8
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Turn on the climate control? What saving do you think you are making? 2023 P440e SE Dynamic on order -cancelled
Just run the climate control system. You'll save three fifths of |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
Mine is on all year round, I had endless arguments with my wife about using aircon because someone told her years ago that it used much more fuel.
As said, that is just normal, when you turn the AC off |
I never understand people buying 2.5t SUVs and then worrying about a tiny bit of fuel usage. You want to save fuel? You're in the wrong vehicle. 2012 SDV6 - it's missing a couple of cylinders
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I turned the instant consumption display on the other day out of curiosity (and because I wondered if my intermittent fault was having a permanent impact on "economy") and boy are you not wrong there.. single digits off every roundabout and junction |
