![]() | Home > Technical > L319 3.0 SDV6 engine cut out. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
If it won't turn over with a bar on it .. my guess would be the crank having become two smaller cranks |
Scotty1980 Member Since: 08 May 2022 Location: Somerset Posts: 30 ![]() ![]() ![]() |
Hey Aaronjb,
The starter should disengage from the flexplate.. but a friend did have a chunk of starter snout break off and jam the flexplate in his Audi so it is possible!
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
I know the signs don't look good, but I can't understand why the battery is soo low, as at 11V it's really |
Hi gogsy1956,
Could the alternator have failed and seized? A failed alternator would obviously result in a battery becoming depleted. 2012 SDV6 - it's missing a couple of cylinders
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
But he would have had the alternator warning light glowing prior to the engine stopping…it’s a diesel so would normally run on anyway. The low voltage subsequently is likely to be him trying to start a seized engine… |
Good point. 2012 SDV6 - it's missing a couple of cylinders
Hi everyone,
We all have our fingers crossed for you! Hope it works out… |
Hello everyone.
We have a 2013 Kahn RRS with a replaced 3.0 SDV6 in it at the shop. The goons who replaced it didn’t tighten the crank shaft pulley. Looks like the guy needs another engine. Ouch. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Barum Engines aren't a million miles away from Zummerzet: https://barumenginesltd.com/ - They have a youtube channel which is how I found them, but they seem to very much know their onions on just about every engine going.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
