Home > Technical > L319 3.0 SDV6 engine cut out. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
If it won't turn over with a bar on it .. my guess would be the crank having become two smaller cranks 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Thu Aug 11 2022 4:33pm |
Scotty1980 Member Since: 08 May 2022 Location: Somerset Posts: 30 |
Hey Aaronjb,
Thu Aug 11 2022 4:39pm |
The starter should disengage from the flexplate.. but a friend did have a chunk of starter snout break off and jam the flexplate in his Audi so it is possible!
Thu Aug 11 2022 4:48pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I know the signs don't look good, but I can't understand why the battery is soo low, as at 11V it's really . Even if the worst has happened how is the battery like it is. You say it went dead,,,, is that like no dash lights at all 2010 RRS, TDV8
Thu Aug 11 2022 7:38pm |
Hi gogsy1956,
Fri Aug 12 2022 8:04am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Could the alternator have failed and seized? A failed alternator would obviously result in a battery becoming depleted. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 12 2022 8:44am |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 535 |
But he would have had the alternator warning light glowing prior to the engine stopping…it’s a diesel so would normally run on anyway. The low voltage subsequently is likely to be him trying to start a seized engine… |
Fri Aug 12 2022 10:09am |
Good point. 2012 SDV6 - it's missing a couple of cylinders
Fri Aug 12 2022 1:48pm |
Hi everyone,
Sat Aug 13 2022 6:25am |
We all have our fingers crossed for you! Hope it works out… |
Sun Aug 14 2022 9:14pm |
Hello everyone.
Sun Sep 04 2022 1:14pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
We have a 2013 Kahn RRS with a replaced 3.0 SDV6 in it at the shop. The goons who replaced it didn’t tighten the crank shaft pulley. Looks like the guy needs another engine. Ouch. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Sep 04 2022 1:46pm |
Barum Engines aren't a million miles away from Zummerzet: https://barumenginesltd.com/ - They have a youtube channel which is how I found them, but they seem to very much know their onions on just about every engine going.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Sun Sep 04 2022 3:45pm |
