Home > Maintenance & Modifications > EGR valves 3.0 TDV6 2010 |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 245 |
I did read somewhere that the car would only require re-mapping if the EGR valves were removed totally. If they are just blanked off, they can operate as necessary but obviously, don’t actually do anything.
Sat Aug 06 2022 10:16am |
There is another post about the 2.7 concerning EGR valves. Contact Bell Services for advice and re-mapping. |
Sat Aug 06 2022 10:19am |
Russ2010 Member Since: 05 Aug 2022 Location: West Sussex Posts: 7 |
Thanks for your reply, as both sides of my car are non functional, I guess a remap will be required. There seems to be lots of info on blanking pre 2007 2.7 cars online, but less for a 3.0 tdv6 with a DPF. |
Sat Aug 06 2022 12:41pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Try these guys
Tue Aug 09 2022 6:53am |
Thanks for the info, much appreciated. |
Thu Aug 11 2022 6:52am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 487 |
There’s a lot less on 3.0’s since they aren’t a slap it on and go fix. You’d need the EGR’s mapped out as well as the DPF (they work together) and then the DPF removed and “reworked” so it doesn’t clog. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Aug 11 2022 1:39pm |
Thanks for you guidance and thoughts.
Fri Aug 12 2022 7:11am |
