Home > Maintenance & Modifications > EGR valves 3.0 TDV6 2010
Russ2010
Some guidance required please, as I’m am receiving conflicting advice online.
I have faulty EGR valves on both sides, one stuck open, the other stuck closed.
I have been considering fitting blanking plates and understand that the ECU will need to be re-mapped. My car has a DPF.
My first question is, given the cost saving of repairs (my main motivation), should I go down the blanking route?
Secondly, if yes, does anybody here have a sense of what the re-mapping costs might be, I’m in West Sussex.
Many thanks, in advance.
Post #625939 Fri Aug 05 2022 2:00pm
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I did read somewhere that the car would only require re-mapping if the EGR valves were removed totally. If they are just blanked off, they can operate as necessary but obviously, don’t actually do anything.
Whether this information is correct or not, I do not know.
Post #625960 Sat Aug 06 2022 10:16am
Salisburylander
There is another post about the 2.7 concerning EGR valves. Contact Bell Services for advice and re-mapping.
Post #625961 Sat Aug 06 2022 10:19am
Russ2010
Thanks for your reply, as both sides of my car are non functional, I guess a remap will be required.
There seems to be lots of info on blanking pre 2007 2.7 cars online, but less for a 3.0 tdv6 with a DPF.
Post #625971 Sat Aug 06 2022 12:41pm
DrRob
Try these guys
http://www.cmsgarages.co.uk/
I know they've done EGR and DPF "work" Whistle Wink Visitor from fullfatrr.com
Post #626010 Tue Aug 09 2022 6:53am
Russ2010
Thanks for the info, much appreciated.
Post #626058 Thu Aug 11 2022 6:52am
NoExpert
There’s a lot less on 3.0’s since they aren’t a slap it on and go fix. You’d need the EGR’s mapped out as well as the DPF (they work together) and then the DPF removed and “reworked” so it doesn’t clog. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626062 Thu Aug 11 2022 1:39pm
Russ2010
Thanks for you guidance and thoughts.
It sounds like I need to bite the bullet and replace both EGR valves.
Many thanks.
Post #626075 Fri Aug 12 2022 7:11am
