Home > Technical > 2012 Interior Boot Trim Removal?
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Afternoon,
So my new powered boot strut arrived today and I need to fit it ASAP so I can start using the boot!
The process looks pretty straightforward, however I know I need to get into the boot to unplug the electrical connector. I have searched the forum and YouTube and all the matches relate to either removal of the exterior boot trim or the interior but on a pre-facelift which has the split tailgate.
Does anyone have any pointers on the fixing points/screws that I need to remove in order to reach the electrical socket??
Si 2012 RRS HSE SDV6 - current
2006 911 Carrera convertible
2016 L200 Barbarian pickup
2010 RRS Lux
2008 E93 M3
2004 VX220 Turbo Stg 2
2010 E70 X5 30d M Sport
2006 Golf R32
Post #625442 Fri Jul 15 2022 1:13pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
I removed mine recently to remove the silver trim to get it painted.
You need to remove the interior handle, (Clip on cover then 2 x torx screws) then remove the 2 off side trims (Gently pull away) then the main trim is held in with loads of push clips
Post #625443 Fri Jul 15 2022 1:59pm
Sit
Thanks ever so much that’s really helpful and sounds quite straightforward. Do the clips come out ok or tend break - just wondering if it’s worth me ordering some in advance??
2010 RRS Lux
2008 E93 M3
2006 Golf R32
Post #625451 Fri Jul 15 2022 5:03pm
Crraigymmmmm
They should be OK. Just line them up well when putting g back. 1 off them is a fir tree clip so might be worth paying close attention to that one. It's the opposite side to to interior handle
Post #625455 Fri Jul 15 2022 6:07pm
Have posted these instructions for the one piece tailgate several times previous, may help a little.
https://drive.google.com/file/d/1hU8JTnoMM...sp=sharing
Post #625460 Fri Jul 15 2022 8:54pm
Sit
Thanks Col, I tried the search but it brought up everything but what I was looking for, this is perfect!
2010 RRS Lux
2008 E93 M3
2006 Golf R32
Post #625466 Sat Jul 16 2022 7:03am
