Home > General (L494) > Does petrol RRS have oil dilution issues |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 |
No, the SCV8 is pretty bulletproof. The only issue you will have is paying for the petrol because of the permagrin caused by a heavy foot
Wed Jun 08 2022 7:14am |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 |
Hi Naks
Wed Jun 08 2022 11:55am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 |
I do hope it's the one at the front of the engine, and not the heater one at the rear of the engine. I think it is referred to as the heater X over pipe or possibly manifold.
Thu Jun 09 2022 5:41am |
It's the one that sandwiched between the engine block and the supercharger, so quite a big job labour-wise.
Thu Jun 09 2022 7:02am |
Thanks Naks - hugely useful reply as always.
Thu Jun 09 2022 6:40pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1853 |
Have a wander around this USA based forum where they have a high percentage of the V8
Thu Jun 09 2022 9:23pm |
That picture is not relevant to a RRS2 S/C because it is pipe LR018275 from a 5.0L Naturally Aspirated Engine as fitted to the D4, RRS1 etc. Don't think they ever fitted the N/A engine to the RRS2 unless it was for a specific market but wouldn't know. N/A to the Left, S/C to the Right, as the S/C pipe consists of two parts wondered if it is remotely possible to replace it without actually removing the Supercharger, think it would be worth a try as couldn't be any worse off if it didn't work, would think if the heater manifold one at the rear of the engine had to be replaced would certainly have to remove S/C. Cheers Col |
Fri Jun 10 2022 4:22am |
Sorry, you're right Col, my mistake
Fri Jun 10 2022 8:27am |
That's rather odd, do you have the part number for the one piece pipe? as L/R are still listing it as two pieces, if I read it correctly the original part numbers LR050935 & LR050934 are saying no longer available although they are available as pattern parts i.e Britpart. one number LR050934 does appear to supersede to LR090630 the other part that goes with that is LR092992 but that is for later cars, so not sure if that half will fit earlier cars though. Not having seen a new pipe I did wonder if it means still in two parts but each bit was moulded as one piece as opposed to what looks a bit like two halves bonded together.
Fri Jun 10 2022 9:16am |
If I look at this breakdown from https://landrover.lakeridgeparts.com/a/Lan...40095.html
Sat Jun 11 2022 8:05am |
but tbf, I just told my indie to replace the crossover coolant pipe, and they knew exactly what to do, since they'd seen many such failures. --
Sat Jun 11 2022 8:16am |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 |
Just do the oil and filter change when the service tells you and you will be ok. The algorithm estimates when fuel dilution has reached the level when the oil needs changing. |
Sat Jun 11 2022 11:58am |
