Home > Faults & Fixes > Range Rover Sport sdv6 tapping sound
Hunvaakaren
Hi.
I recently fitted my new overhauled engine to my Range Rover sport 2012 sdv6.
The work shop moved over all the external from my engine, electric, cylinder heads, turbos etc et.
Started it up and it has a tapping sound, sound like it comes from the left side of the engine (while you sit in the car).
The reason I fit in a new overhauled engine is that my got run dry and one of the bearings on the crank shaft failed.
Does anyone recognize the sound or what could this be?
See video from first start. It does use some time to start as well.
https://youtube.com/shorts/U-x0WfveyjU?feature=share
The only fault I get with the iidtool is these:
Thanks.
Post #622858 Wed Mar 16 2022 2:38pm
Scotty1980
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi Hunvaakaren
Did you get the tapping sound repaired?
I have a similar sound (not as loud) and I have been told Tappets, injectors, exhaust manifold.
Hope it’s not the dreaded crankshaft though
Post #624528 Sat May 28 2022 8:57am
