Home > Technical > 4.2 Supercharged PCV System |
dhallworth Member Since: 13 Aug 2015 Location: Glasgow Posts: 40 |
Supercharger is now removed.
Thu Apr 28 2022 9:38pm |
Tonight saw a bit more time on the lathe to make an adapter for the smoke tester
Fri Apr 29 2022 11:19pm |
Sat Apr 30 2022 7:03pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Couldn't the chain issues, just be where the engine stopped, if you were to rotate it round, maybe that would look different ?
Sun May 01 2022 9:11am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
if you want to keep running LPG you'll wanna get hardened seats in those heads. |
Sun May 01 2022 9:20am |
I’ve done a full rotation of the engine (8 revolutions of the crank) and the tensioner didn’t move.
Sun May 01 2022 11:53am |
a budget fix for 40-50k i think is to just reshim the engine. but sometimes it might be too past it for that.
Mon May 02 2022 8:50am |
Yea, it’s got a pumped flashlube kit fitted to it.
Mon May 02 2022 7:53pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 345 |
Hopefully found my evap leak fingers crossed it doesn't escalate like yours
Wed May 04 2022 7:48pm |
Is that the rigid plastic pipe? If so, mine was leaking there too.
Wed May 04 2022 8:06pm |
Indeed it is and I've had a good read and saw your post regards this but only now realised its the same part |
Wed May 04 2022 8:16pm |
O ring replaced hopefully my vac leak issues are fixed smoke test passed OK fingers crossed for yours |
Thu May 05 2022 7:05pm |
I’m getting mine stripped. Tool to remove the crank pulley arrived yesterday.
Fri May 06 2022 10:22pm |
More progress has been made today!
Sat May 07 2022 8:43pm |
