![]() | Home > Technical > 4.2 Supercharged PCV System |
dhallworth Member Since: 14 Aug 2015 Location: Glasgow Posts: 47 ![]() ![]() |
Supercharger is now removed.
Tonight saw a bit more time on the lathe to make an adapter for the smoke tester |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
Couldn't the chain issues, just be where the engine stopped, if you were to rotate it round, maybe that would look different ?
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
if you want to keep running LPG you'll wanna get hardened seats in those heads. |
I’ve done a full rotation of the engine (8 revolutions of the crank) and the tensioner didn’t move.
a budget fix for 40-50k i think is to just reshim the engine. but sometimes it might be too past it for that.
Yea, it’s got a pumped flashlube kit fitted to it.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Hopefully found my evap leak fingers crossed it doesn't escalate like yours
Is that the rigid plastic pipe? If so, mine was leaking there too.
Indeed it is and I've had a good read and saw your post regards this but only now realised its the same part |
O ring replaced hopefully my vac leak issues are fixed smoke test passed OK fingers crossed for yours |
I’m getting mine stripped. Tool to remove the crank pulley arrived yesterday.
More progress has been made today!
