Home > Technical > horn not working |
supertramp Member Since: 24 Dec 2017 Location: Northern Ireland Posts: 11 |
Wed Apr 20 2022 4:34pm |
Hi Andy,
Wed Apr 20 2022 6:43pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
You won’t find the relay
Wed Apr 20 2022 8:57pm |
Hi Andy,
Thu Apr 21 2022 9:00am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
The horn relay is a integral part of the CJB so you won't find it separate. If it needs to be replaced I think it may be a replacement CJB. Do you have any fault codes ? as there are some associated with the relay.
Thu Apr 21 2022 9:41am |
I had forgotten to mention this (sorry) I did do a fault scan with IDD tool when I first discovered I had an issue with the horn and retrieved the following code in relation to the horn:-
Thu Apr 21 2022 10:00am |
Hi Col,
Thu Apr 21 2022 10:35am |
We need to check the diagram to see if the alarm activates the same relay
Thu Apr 21 2022 12:34pm |
Hi Andy,
Thu Apr 21 2022 3:58pm |
Ok, I'm now on the comouter and checked.
Thu Apr 21 2022 4:21pm |
Hi Andy,
Thu Apr 21 2022 8:58pm |
If it is needed, you can buy the small switch to clock spring wiring harness inside the steering wheel separate. About £30.00 a new CJB would be best part of £500.00.
Thu Apr 21 2022 9:25pm |
Hi Col,
Fri Apr 22 2022 12:31pm |
Tue Apr 26 2022 7:39pm |
