![]() | Home > Technical > horn not working |
supertramp Member Since: 24 Dec 2017 Location: Northern Ireland Posts: 11 ![]() ![]() ![]() |
Hi Andy,
You won’t find the relay
Hi Andy,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
The horn relay is a integral part of the CJB so you won't find it separate. If it needs to be replaced I think it may be a replacement CJB. Do you have any fault codes ? as there are some associated with the relay.
Cheers Col |
I had forgotten to mention this (sorry) I did do a fault scan with IDD tool when I first discovered I had an issue with the horn and retrieved the following code in relation to the horn:-
Hi Col,
We need to check the diagram to see if the alarm activates the same relay
Hi Andy,
Ok, I'm now on the comouter and checked.
Hi Andy,
If it is needed, you can buy the small switch to clock spring wiring harness inside the steering wheel separate. About £30.00 a new CJB would be best part of £500.00.
Hi Col,
