![]() | Home > Maintenance & Modifications > RRS 2008 fuel tank cradle |
Yes, that is holding the tank in place
GerryG Member Since: 07 Jul 2019 Location: Coatbridge Posts: 27 ![]() ![]() |
Hi Mikey Not as bad but has a hole after I prodded around, your not far from me but my car isnt road legal yet, as I am doing work on the brakes and bodywork, is there a write up I could borrow ? Where do you pick one of the cradles up from, Ebay? |
Not sure there is a write up. Essentially, disconnect breather and filler pipes, remove front fuel pipes at filter housing, lower tank, unplug wiring and drop tank
Thanks Mike
Wasn't as bad as I first thought. Job done with rope and a little patience. Cheers Gerry |
Yellopin Member Since: 18 Jul 2019 Location: Telford Posts: 12 ![]() ![]() ![]() |
Did mine today, took about 2 hours with a block of wood and ratchet strap. Concerned about having 1/4 of tank of fuel left but was nowhere near as bad as I thought it would be. Added a couple of coats of waxoyl underseal to the inside face before fitting. (Any little bit helps I guess?). ![]() 2014 Evoque Dynamic Fuji 2.2 (SHMBO’s) 2000 Discovery 2 GS 1980 Series 3 2.25 petrol Rag top |
supertramp Member Since: 24 Dec 2017 Location: Northern Ireland Posts: 11 ![]() ![]() ![]() |
Hi
