Home > Maintenance & Modifications > RRS 2008 fuel tank cradle
GerryG
Scotland
Hi Guys
I was changing the brake pads and discs on a 08 3.6 tdv8 that I have just bought, while underneath I saw bad corrosion in the cover that goes over the fuel tank. poked around and it just holed on me.
Anyone ever replaced this? wondering if the tank will fall if I remove it?
Gerry
Post #586176 Sun Sep 01 2019 7:39am
Disco_Mikey
Yes, that is holding the tank in place
When you unbolt the cradle, the tank will come down
Replaced loads of them, all due to corrosion
Post #586180 Sun Sep 01 2019 7:54am
Disco_Mikey
Hopefully it's not as bad as this one Laughing
Post #586181 Sun Sep 01 2019 7:57am
GerryG
Scotland
Hi Mikey
Not as bad but has a hole after I prodded around, your not far from me but my car isnt road legal yet, as I am doing work on the brakes and bodywork, is there a write up I could borrow ?
Where do you pick one of the cradles up from, Ebay?
Post #586182 Sun Sep 01 2019 8:02am
Disco_Mikey
Not sure there is a write up. Essentially, disconnect breather and filler pipes, remove front fuel pipes at filter housing, lower tank, unplug wiring and drop tank
With a ramp and a 2nd pair of hands, it can be done without dropping the tank
AFAIK, they are only available as a genuine LR part
Post #586186 Sun Sep 01 2019 8:26am
GerryG
Scotland
Thanks Mike
Was hoping to avoid dropping the tank, dont want to start messing around with fuel pipes, getting scunnered already with this jeep.
Post #586187 Sun Sep 01 2019 8:32am
GerryG
Scotland
Re: RRS 2008 fuel tank cradle
GerryG wrote:
Hi Guys
Gerry
Wasn't as bad as I first thought. Job done with rope and a little patience.
Gerry
Post #597925 Mon Apr 20 2020 11:48am
Yellopin
Did mine today, took about 2 hours with a block of wood and ratchet strap. Concerned about having 1/4 of tank of fuel left but was nowhere near as bad as I thought it would be. Added a couple of coats of waxoyl underseal to the inside face before fitting. (Any little bit helps I guess?).
 2007 3.6 HSE Java
2014 Evoque Dynamic Fuji 2.2 (SHMBO’s)
2000 Discovery 2 GS
1980 Series 3 2.25 petrol Rag top
Post #623574 Wed Apr 13 2022 10:21pm
supertramp
United Kingdom 2008 Range Rover Sport TDV8 HSE Lucerne Green
Hi
I replaced my cradle a few months ago and found this floating around the net. I found it very useful and completed the job in about five hours with the car on the ground, I've no access to a lift
https://trialsofarrsowner.wordpress.com/1-...-corroded/
Hope this helps,
David
Post #624028 Tue May 03 2022 10:14pm
