Home > Maintenance & Modifications > RRS 2008 fuel tank cradle |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Yes, that is holding the tank in place
Sun Sep 01 2019 7:54am |
Sun Sep 01 2019 7:57am |
GerryG Member Since: 07 Jul 2019 Location: Coatbridge Posts: 27 |
Hi Mikey Not as bad but has a hole after I prodded around, your not far from me but my car isnt road legal yet, as I am doing work on the brakes and bodywork, is there a write up I could borrow ? Where do you pick one of the cradles up from, Ebay? |
Sun Sep 01 2019 8:02am |
Not sure there is a write up. Essentially, disconnect breather and filler pipes, remove front fuel pipes at filter housing, lower tank, unplug wiring and drop tank
Sun Sep 01 2019 8:26am |
Thanks Mike
Sun Sep 01 2019 8:32am |
Wasn't as bad as I first thought. Job done with rope and a little patience. Cheers Gerry |
Mon Apr 20 2020 11:48am |
Yellopin Member Since: 18 Jul 2019 Location: Telford Posts: 12 |
Did mine today, took about 2 hours with a block of wood and ratchet strap. Concerned about having 1/4 of tank of fuel left but was nowhere near as bad as I thought it would be. Added a couple of coats of waxoyl underseal to the inside face before fitting. (Any little bit helps I guess?). 2007 3.6 HSE Java 2014 Evoque Dynamic Fuji 2.2 (SHMBO’s) 2000 Discovery 2 GS 1980 Series 3 2.25 petrol Rag top |
Wed Apr 13 2022 10:21pm |
supertramp Member Since: 24 Dec 2017 Location: Northern Ireland Posts: 11 |
Hi
Tue May 03 2022 10:14pm |
