![]() | Home > General (L494) > SIDE STEPS |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 ![]() ![]() ![]() |
Turdmon if you call them and arrange to have them fitted for free actually cheaper £350 cash |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 124 ![]() ![]() |
Nice mate. Thanks for that. I'll probably have a nip down the M6 then as it won't cost me £50 in diesel. |
R4zb3rry Member Since: 28 Feb 2015 Location: Leicester Posts: 43 ![]() ![]() |
I’ve just purchased some sidesteps (not from sidesteps sadly as bought before seeing this thread) and they require cutting the plastic trim under the car - this isn’t an issue but, I am having serious issues with installing the nearside rear bracket as there are a couple of metal pipes (fuel) obstructing the threaded hole and I can seem to move them enough to locate the bracket. Has anyone (tyrefitter maybe?) come across this and resolved?
Mmmm that’s the side where the fuel pipes run which you need to watch out when cutting plastic trim that you don’t catch a pipe but I’ve never come across where the bracket are close to the the pipes,,can you take a pic & post it.? Andy.
Hi Tyrefitter, thanks for the reply.
Hi,the only ones I’ve ever fitted are like the ones in the link below & never had any problems fitting.The brackets you have posted,I’ve never seen them befor.
Thanks, those are the brackets shown in the page of the item I purchased but, when they arrived they were the ones above.
Hi Tyrefitter, just for confirmation do you find that the rear brackets are usually a different design/shape between near and offside as I believe this is the issue with the set I have received, with them both being the same design there is no consideration of the brake/fuel lines on the nearside. Thanks |
Yes the rears are totally different for the reason of the fuel pipes.If you look at the 2nd & 4th bracket,you can see the difference for clearance of fuel pipes.
