Home > General (L494) > SIDE STEPS
Tyrefitter
I’ve fitted loads of different brands but I find these the best quality & easiest to fit. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #622833 Tue Mar 15 2022 12:48pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
Turdmon if you call them and arrange to have them fitted for free actually cheaper £350 cash
Post #622868 Wed Mar 16 2022 7:17pm
Turdmon
Nice mate. Thanks for that. I'll probably have a nip down the M6 then as it won't cost me £50 in diesel.
Post #622869 Wed Mar 16 2022 8:46pm
R4zb3rry
I’ve just purchased some sidesteps (not from sidesteps sadly as bought before seeing this thread) and they require cutting the plastic trim under the car - this isn’t an issue but, I am having serious issues with installing the nearside rear bracket as there are a couple of metal pipes (fuel) obstructing the threaded hole and I can seem to move them enough to locate the bracket. Has anyone (tyrefitter maybe?) come across this and resolved?
Model is 2017 SCV8.
Thanks
Post #623173 Mon Mar 28 2022 12:41pm
Tyrefitter
Mmmm that’s the side where the fuel pipes run which you need to watch out when cutting plastic trim that you don’t catch a pipe but I’ve never come across where the bracket are close to the the pipes,,can you take a pic & post it.? Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #623175 Mon Mar 28 2022 1:27pm
R4zb3rry
Hi Tyrefitter, thanks for the reply.
Pictures attached of the bracket and then the issue when trying to align.
The bracket doesn’t extend over the pipes and then I can’t seem to move the pipes enough to squeeze the bracket under.
Can’t remember ever having these issues when I gotten steps to my L320!
Post #623179 Mon Mar 28 2022 2:09pm
Tyrefitter
Hi,the only ones I’ve ever fitted are like the ones in the link below & never had any problems fitting.The brackets you have posted,I’ve never seen them befor.
https://www.ebay.co.uk/itm/154487863294?_t...BMlNa63Ppf Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #623211 Tue Mar 29 2022 1:06pm
R4zb3rry
Thanks, those are the brackets shown in the page of the item I purchased but, when they arrived they were the ones above.
I have contacted the seller repeatedly demonstrating how they do not fit however, now the seller is stonewalling me saying to get a garage to fit them (which I think is quite dismissive) and they are adamant they are 100% correct.
Bit of a nightmare tbh as all the other brackets are simple to fit, even taking into account the dremelling of the plastic trim.
Post #623212 Tue Mar 29 2022 1:15pm
R4zb3rry
Hi Tyrefitter, just for confirmation do you find that the rear brackets are usually a different design/shape between near and offside as I believe this is the issue with the set I have received, with them both being the same design there is no consideration of the brake/fuel lines on the nearside.
Thanks
Post #623213 Tue Mar 29 2022 1:27pm
Tyrefitter
Yes the rears are totally different for the reason of the fuel pipes.If you look at the 2nd & 4th bracket,you can see the difference for clearance of fuel pipes.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #623215 Tue Mar 29 2022 2:07pm
