Home > Technical > Jack car up normal height only
fatladandy
United Kingdom 2010 Range Rover Sport TDV8 HSE Java Black
Hi Guys
I need to replace the front lower arm on my 2009 RRS. However I have the normal height only fault showing. how is best to jack the vehicle with out damaging the airbag?
Thanks
Post #621746 Thu Feb 10 2022 3:54pm
fine to jack it , in normal height
Post #621748 Thu Feb 10 2022 6:13pm
Jack it on the chassis as shown in the owners handbook. Or on the suspension arm as they often do in tyre places. Either way, you're putting axle stands under it so it's all good. 2012 SDV6 - it's missing a couple of cylinders
Post #621750 Thu Feb 10 2022 6:30pm
knwatkins
You need to jack it up with the vehicle set at standard height when replacing suspension arms. The reason being, you need to have the distance between the centre of the hub and the bottom of the wheel arch set at 462mm when you tighten the bolts up. You'll struggle to achieve this if you jack up at off-road height! Kev
Post #621760 Thu Feb 10 2022 9:37pm
And you really need to tighten the bolts when the vehicle is sat on the ground / on a ramp so that they are tightened in the correct orientation. 2012 SDV6 - it's missing a couple of cylinders
Post #621761 Thu Feb 10 2022 11:18pm
Or a jack under the strut/disc, ensuring it’s at the correct height
Post #621769 Fri Feb 11 2022 11:14am
