Home > Technical > Jack car up normal height only |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
fine to jack it , in normal height |
Thu Feb 10 2022 6:13pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Jack it on the chassis as shown in the owners handbook. Or on the suspension arm as they often do in tyre places. Either way, you're putting axle stands under it so it's all good. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 10 2022 6:30pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
You need to jack it up with the vehicle set at standard height when replacing suspension arms. The reason being, you need to have the distance between the centre of the hub and the bottom of the wheel arch set at 462mm when you tighten the bolts up. You'll struggle to achieve this if you jack up at off-road height! Kev
Thu Feb 10 2022 9:37pm |
And you really need to tighten the bolts when the vehicle is sat on the ground / on a ramp so that they are tightened in the correct orientation. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 10 2022 11:18pm |
Or a jack under the strut/disc, ensuring it’s at the correct height |
Fri Feb 11 2022 11:14am |
