Home > Faults & Fixes > Coolant Leak
dukeminster
Coolant Leak
Hi Guys, can anyone point me in the right direction with a coolant leak? The engine water is running at normal temperature on long drives but it is dumping out a bottle of coolant in about 48 hours. Please see attached photo.
Is there a point in the system that is prone to leaks?
After some googling I found this...seem likely?
https://www.landrovermonthly.co.uk/article...lant-leak/
Post #621687 Tue Feb 08 2022 5:40pm
NoExpert
Unfortunately the best thing is to get in there and look around. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #621707 Wed Feb 09 2022 7:11am
I don’t recall a steel pipe.
There is lots to leak on passenger corner.
Thermostat
Fbh
Tank
Loads of pipes.
Engine plastic inlet
Check the top of the engine , at the front , in the middle Vee. The black plastic thing is most common to leak.
Post #621708 Wed Feb 09 2022 7:39am
