Home > General (L494) > Stolen
Kenniff
Scotland
Stolen
So my RRS MY 2021 with Cat 5 tracker was stolen from outside my front door on 30th Dec.
9 months old and in perfect condition. Taken despite bothe keys being in my house and in faraday pouches.
Bit gutted. current: RRS HST P400 engine ( 2021) Hakuba silver
Post #620567 Wed Jan 05 2022 12:38am
Nveeate
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Sorry to hear that. At least they didn’t break in for keys I suppose. Hopefully the insurers will get you in a replacement soon - are you going to get the same again?
Post #620568 Wed Jan 05 2022 6:53am
Kenniff
Scotland
That’s a good question!
There’s a “replacement with new” cover under the insurance policy, so I may need to go for the same again to get the best settlement. I liked the car, I’m just a bit concerned any replacement will get nicked too. current: RRS HST P400 engine ( 2021) Hakuba silver
Post #620570 Wed Jan 05 2022 9:06am
Tyrefitter
Sorry to hear about your rrs,,is their any cctv in the area which will help how they took it if keys were in faraday pouch,also I thought they’d updated the new keys so they can’t be scanned.Have you checked your faraday pouch as the only seem to last for so long & I recommend if you get a replacement vehicle get a disk lock,that’s what I now have & if they see that they probably go on to the next car. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #620571 Wed Jan 05 2022 9:20am
Farmer Chalk
I was of the understanding that a 21 MY could not be stolen by rebroadcasting…
It is more likely a key was coded for it previously…whilst parked at airport car park, car wash, valet parking etc…
Had you ever left the car alone with a third party? Or ever unlocked on your drive…
With the Cat 5 you should have been told of a movement alert? Did this happen?
Post #620574 Wed Jan 05 2022 10:03am
timhum
I reckon your biggest issue will be getting a new car without a very long wait.
Tim Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #620577 Wed Jan 05 2022 11:29am
Kot
Did you have keyless entry switched on? regardless if they are in pouches, most pouches are not big enough to fit key fob and attached ironmongery etc.
Do you not use Guardian mode on the Incontrol app? it even reminds you now if you haven't locked your car after 15mins.
Guardian mode is a must, even if you forget and unlock the car, Tracker Company get a Red Alert and they call you Embarassed
the keys are using wide band technology and only keyless or someone who has had possession of your keys and then make a copy can deactivate alarm and immobiliser
Post #620578 Wed Jan 05 2022 11:31am
Kitchenfitter
Get a Ghost fitted on next car and a independant tracker as scumbags know where the factory trackers are. Only costs around £650 for both and worth every penny if you consider the inconvenience and stress to sort out RRS HSE DYNAMIC 2015 ODESSEY RED
Post #620581 Wed Jan 05 2022 12:37pm
Kenniff
Scotland
Tim
I think you are exactly right. current: RRS HST P400 engine ( 2021) Hakuba silver
Post #620584 Wed Jan 05 2022 4:16pm
Kenniff
Scotland
Key pouches fit easily and were working fine. I’d only done 6500 miles. Keyless was switched on (which I won’t be doing again). Cat 5 notification worked - the car told me it had been stolen less than 2 minutes after it was taken. Car spotted on cctv at the end of the road but no one identified.
Spent 15 minutes on hold to the police before I could get through…
GPS disabled immediately (probably a short range jammer). GSM lost 30 minutes later, probably when they got to where they were going. Before it ceased jlr could see it moving cell tower to cell tower. current: RRS HST P400 engine ( 2021) Hakuba silver
Post #620586 Wed Jan 05 2022 5:59pm
Kitchenfitter
Nightmae for you RRS HSE DYNAMIC 2015 ODESSEY RED
Post #620587 Wed Jan 05 2022 6:11pm
I'd have used 999 or did it take 15 minutes to get through on that? 2012 SDV6 - it's missing a couple of cylinders
Post #620588 Wed Jan 05 2022 6:31pm
Kenniff
Scotland
Stupidly, first thing i did was ring JLR, to confirm it was a theft. They told me to use 101 to report it which again with hindsight might not have been the best decision. current: RRS HST P400 engine ( 2021) Hakuba silver
Post #620590 Wed Jan 05 2022 7:20pm
Farmer Chalk
For future info, as suspected a 21MY cannot currently be attacked by rebroadcasting. However it is possible to code it a new emergency key to recover the vehicle but not open vehicle doors..
However the thieves need an unlocked vehicle or to be able to break a window to access the obd to do this…
Therefore people must ensure their vehicle is locked before walking away from it! Thieves are currently using blockers to drown the signal from the owners key. This can be a device planted nearby which stops the lock signal from the owners key reaching the car.. therefore you must ensure it’s locked by watching the mirrors fold back before leaving it..otherwise you literally leave it wide open to the car thieves…
Post #620659 Fri Jan 07 2022 10:03pm
louischristie8
2005 Range Rover Sport Supercharged Java Black
Nope, they just pull the lock cover off the drivers door and use a lock pick to unlock the car. They did it to mine then used an emergency start. Whole things takes less than 2 mins
Post #621112 Wed Jan 19 2022 8:47pm
