![]() | Home > General (L494) > Stolen |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
The first thing to buy after you get your new motor is a Ghost |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 349 ![]() ![]() |
Also a independant tracker, disc lock and telescopic anti ram posts
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
The posts look good, do you just unlock and press down or are they super dooper automatic |
Just remove each padlock lift and lower
Kenniff Member Since: 04 Feb 2021 Location: London Posts: 55 ![]() ![]() |
Yup, lesson learned, i will def be fitting a ghost immobiliser. current: RRS HST P400 engine ( 2021) Hakuba silver |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Does remote start work with Ghost now? No pre-heating would be a “red line” for me. RRS MY17 SDV6 AB
It should work with Ghost as you can deactivate via Ghost app. But some say if you have app it can be hacked so I def dont use Ghost app RRS HSE DYNAMIC 2015 ODESSEY RED |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 542 ![]() |
I think walking to work and the supermarket would probably me even more of a red line …. |
Remote start doesn't work with Ghost unless you use the app, not sure the app is hacked its just that if your phone is within range Ghost is disabled. I dont use the app, but my red line would be waking up and the car was being pre-heated on someone else's drive ![]() ![]() ![]() |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 ![]() |
My since sold SVR allowed for remote start via the InControl app with a ghost fitted. The installer I had do it said there had been “a way” to fit the device been developed to allow for this very scenario.
You are correct, there is an option to either have Engine block or Transmission block.
MaximusDM Member Since: 04 May 2017 Location: London Posts: 52 ![]() |
I had a ghost 2 fitted to my 21.5MY p400e and was told on the day of install that remore star wouldn't work to pre heat cabin etc. They were right with the ICE but can happily use the electric battery to pre heat. |
