Home > Faults & Fixes > Cutting out whilst driving |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5020 |
I will ask the obvious, but do you have plenty of fuel in it ? as you say something about a fuel sender issue, only there is a TSB around with regards to the wiring on the sender which can also give false fuel level readings. Failing that I think you may need to have any fault codes read if there are any, which may point you in the right direction.
Thu Dec 23 2021 10:15pm |
S77EVX Member Since: 23 Dec 2021 Location: Pewsey Posts: 8 |
Hi Col, yes I only filled it up yesterday and from a fuel station that we always use.
Thu Dec 23 2021 10:25pm |
Ian335 Member Since: 09 Oct 2019 Location: Wales Posts: 16 |
I have the same year and spec.This was happening to me a couple of years ago. I thought fuel problems,battery,brake light switch. Sometimes dashboard lights came on,sometimes not.What seemed to happen when it was stopping was a message saying vehicle was lowering. I related the tale of woe to a local independent. He said straight away faulty crank angle sensor. A diagnostic check said he was right. New sensor fitted,been great since. |
Fri Dec 24 2021 7:23am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
From what I understand, if you have the fuel gauge sender issue, even if you have a full tank the car thinks you are running out and executes a protocol to protect the the injection system and cuts the engine out.
Fri Dec 24 2021 8:22am |
Thank you, the only thing is I don’t have any lights come on it just cuts out. I’m getting it on my mates fault reader after Christmas. |
Fri Dec 24 2021 9:13am |
Thank you for your comments and what you are saying makes perfect sense it’s just it’s not done this prior when the sender fault has been there. I was hoping to wait for better weather before having to drop the tank. |
Fri Dec 24 2021 9:15am |
I have to confess that rather than get dirty and really smelly I took it to the indi I used at the time, so all new but quite expensive. I don't envy you doing it yourself but fingers crossed |
Fri Dec 24 2021 2:54pm |
I don't know if you have a copy of the Technical Bulletin, but here is a link to it I posted a few years back just in case you don't have it, imagine it will still be current.
Fri Dec 24 2021 8:54pm |
Col, that is great thank you.
Mon Dec 27 2021 8:27am |
I think at one time they would repair it FOC if anybody had the issue, but this is L/R so unlikely the will do anything now as they will probably say the time frame has expired, but could always quote the Tech Bulletin and try I suppose.
Mon Dec 27 2021 7:56pm |
Col, I will give them a bell tomorrow as that is when they start back after Christmas.
Tue Dec 28 2021 7:44pm |
Hi, and a happy new year to you, the problem with these vehicles are they are a Love Hate relationship, as soon as it is running properly again the chances are you will change your mind and want to keep it, until you have another issue then it will be a piece of junk and I'm getting rid of it.
Tue Dec 28 2021 9:09pm |
*UPDATE*
Sat Feb 19 2022 10:33am |
