Home > Faults & Fixes > Cutting out whilst driving
S77EVX
England 2011 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Hi again all,
Please could someone throw some light on my current issue as my car has given me an early Christmas present.
I have just been out in my 2011 RRS 3.0 HSE and it was driving as normal.
When it warmed up it started to act like it was having a misfire and started to get progressively worst.
On my way home it started to cut out on me without any warning, I’d pull over, switch off and restart and carry on until it cut out again.
Thankfully I got home and will get round to looking at it after Christmas. The other issue that it has is the fuel sender wire on top of the tank, this has been playing up now on and off for a couple of month’s however I’ve not experienced this issue prior tonight.
Thanks in advance for any help and guidance.
Steve
Post #620234 Thu Dec 23 2021 10:58pm
I will ask the obvious, but do you have plenty of fuel in it ? as you say something about a fuel sender issue, only there is a TSB around with regards to the wiring on the sender which can also give false fuel level readings. Failing that I think you may need to have any fault codes read if there are any, which may point you in the right direction.
Post #620235 Thu Dec 23 2021 11:15pm
S77EVX
Hi Col, yes I only filled it up yesterday and from a fuel station that we always use.
I think I will need to get it on a computer after Christmas. I was surprised not to have any warning lights on the dash.
Thanks again
Steve
Post #620236 Thu Dec 23 2021 11:25pm
Ian335
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
I have the same year and spec.This was happening to me a couple of years ago. I thought fuel problems,battery,brake light switch. Sometimes dashboard lights came on,sometimes not.What seemed to happen when it was stopping was a message saying vehicle was lowering. I related the tale of woe to a local independent. He said straight away faulty crank angle sensor. A diagnostic check said he was right. New sensor fitted,been great since.
Post #620244 Fri Dec 24 2021 8:23am
Oldandconfused
From what I understand, if you have the fuel gauge sender issue, even if you have a full tank the car thinks you are running out and executes a protocol to protect the the injection system and cuts the engine out.
This is what I had in mine and the only warning was the gauge suddenly dropped during a journey then it cut out. There is a fix involving repairing a wire in the tank, or you can fit the senders (there are 2 to buy, obviously).
Of course it may not be this, you probably need the fault codes read.
Post #620245 Fri Dec 24 2021 9:22am
S77EVX
Thank you, the only thing is I don’t have any lights come on it just cuts out. I’m getting it on my mates fault reader after Christmas.
Post #620247 Fri Dec 24 2021 10:13am
S77EVX
Thank you for your comments and what you are saying makes perfect sense it’s just it’s not done this prior when the sender fault has been there. I was hoping to wait for better weather before having to drop the tank.
Post #620248 Fri Dec 24 2021 10:15am
Oldandconfused
I have to confess that rather than get dirty and really smelly I took it to the indi I used at the time, so all new but quite expensive. I don't envy you doing it yourself but fingers crossed Bow down
Post #620257 Fri Dec 24 2021 3:54pm
I don't know if you have a copy of the Technical Bulletin, but here is a link to it I posted a few years back just in case you don't have it, imagine it will still be current.
https://drive.google.com/file/d/15vRZH1JCy...sp=sharing
Post #620266 Fri Dec 24 2021 9:54pm
S77EVX
Col, that is great thank you. Thumbs Up
I don’t believe that Land Rover haven’t placed a recall on the fault as it’s very common.
Post #620291 Mon Dec 27 2021 9:27am
I think at one time they would repair it FOC if anybody had the issue, but this is L/R so unlikely the will do anything now as they will probably say the time frame has expired, but could always quote the Tech Bulletin and try I suppose.
Post #620304 Mon Dec 27 2021 8:56pm
S77EVX
Col, I will give them a bell tomorrow as that is when they start back after Christmas.
After doing some research it’s looking more like the Crankshaft sensor, again this was a recall on 2012 models and mine is late 2011. I’m thinking of once it’s back working to get rid of it but it’s such a good motor when it’s working.
I hope you had a great Christmas and all the best for 2022.
Post #620315 Tue Dec 28 2021 8:44pm
Hi, and a happy new year to you, the problem with these vehicles are they are a Love Hate relationship, as soon as it is running properly again the chances are you will change your mind and want to keep it, until you have another issue then it will be a piece of junk and I'm getting rid of it. Laughing
Post #620319 Tue Dec 28 2021 10:09pm
S77EVX
*UPDATE*
Car finally fixed, it was a broken fuel wire between the tank and engine.
Now I’ll remove the plate and sell the thing before another RR issue starts again.
Post #622052 Sat Feb 19 2022 11:33am
