Home > Faults & Fixes > P4004C-77 Turbo boost control solenoid B circuit low |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
well there are 2 turbos ? maybe the other one ?
Mon Dec 20 2021 12:16pm |
moonstone Member Since: 07 Jan 2021 Location: Scotland Posts: 41 |
The Passenger side turbo is fine as the fault code and limp mode only happen when the drivers side turbo is engaged, which happens above a certain RPM threshold.
Mon Dec 20 2021 12:22pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
P004C-77 isn't a valid DTC
Mon Dec 20 2021 12:35pm |
@Disco_Mikey really appreciate your input. What do you mean by it not being a valid DTC? This is the code being displayed by GAP Tool and is DTC quoted on the initial main dealer report. See below:
Mon Dec 20 2021 1:04pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Any help ?
Mon Dec 20 2021 8:31pm |
Col, my Topix didn't list that fault code |
Mon Dec 20 2021 9:04pm |
Mikey,
Mon Dec 20 2021 9:11pm |
This is a great help Col. Thank you. Gives my guy a bit more clarity on what to check out. Assume it’s the same engine? |
Mon Dec 20 2021 10:39pm |
Found it this time Was it a new or recon turbo fitted? |
Mon Dec 20 2021 10:51pm |
Thanks very much to you both for helping me out.
Mon Dec 20 2021 11:04pm |
As the control module has a stepper motor in it, I was just wondering if it needs calibrating in some way if it has been replaced, I think Disco-Mikey may be the person most able to answer that though.
Mon Dec 20 2021 11:26pm |
Everything points towards a faulty actuator...
Tue Dec 21 2021 5:03am |
Ok. No calibration procedure has been carried out on the car. The mechanic mentioned that there might be one but if so he needs to find out what it is. Is the calibration procedure something that’s done on the bench? If so I believe that the Turbo Guy is supposed to have done all this.
Tue Dec 21 2021 6:41am |
Calibration is done via diag, with the unit fitted to the car
Tue Dec 21 2021 6:53am |
