![]() | Home > Faults & Fixes > P4004C-77 Turbo boost control solenoid B circuit low |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5038 ![]() ![]() ![]() |
well there are 2 turbos ? maybe the other one ?
moonstone Member Since: 07 Jan 2021 Location: Scotland Posts: 41 ![]() ![]() |
The Passenger side turbo is fine as the fault code and limp mode only happen when the drivers side turbo is engaged, which happens above a certain RPM threshold.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
P004C-77 isn't a valid DTC
@Disco_Mikey really appreciate your input. What do you mean by it not being a valid DTC? This is the code being displayed by GAP Tool and is DTC quoted on the initial main dealer report. See below: ![]()
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Any help ?
Col, my Topix didn't list that fault code |
Mikey,
This is a great help Col. Thank you. Gives my guy a bit more clarity on what to check out. Assume it’s the same engine? |
Found it this time ![]() Was it a new or recon turbo fitted? |
Thanks very much to you both for helping me out.
As the control module has a stepper motor in it, I was just wondering if it needs calibrating in some way if it has been replaced, I think Disco-Mikey may be the person most able to answer that though.
Everything points towards a faulty actuator...
Ok. No calibration procedure has been carried out on the car. The mechanic mentioned that there might be one but if so he needs to find out what it is. Is the calibration procedure something that’s done on the bench? If so I believe that the Turbo Guy is supposed to have done all this.
Calibration is done via diag, with the unit fitted to the car
