Home > Faults & Fixes > P4004C-77 Turbo boost control solenoid B circuit low
moonstone
Hi guys,
Hoping for a bit of help. Car is a 2014 L494 3.0 TDV6
After restricted performance messages the main dealer diagnosed that the car needed a new turbo. Our 3rd party warranty’s conditions meant that it couldn’t go to a main dealer for this. Car has been into a indy who has changed the turbo (including actuator etc) and replaced the manifold. Car came back and went into limp mode again. Indy took it back, found oil contamination in the hoses going to the solenoid and replaced it. Car went back into limp mode on the motorway the next day.
GAP Tool has shown the following fault throughout:
P004C-77 (6C) Turbo/supercharger
boost control solenoid B - circuit low
Mechanical failure - commanded
position is not reachable
The Indy has been brilliant to be honest but isn’t a LR specialist. None of the warranty companies approved repairers are. I’ve hunted all over the Internet and cannot find much on this fault code. Also a bit stumped given the solenoid has been replaced as well.
Can anyone share any experience or insight?
Post #620130 Mon Dec 20 2021 12:26am
well there are 2 turbos ? maybe the other one ?
try a bottle of wynns vvt cleaner if loosing faith in garages
Post #620141 Mon Dec 20 2021 12:16pm
moonstone
The Passenger side turbo is fine as the fault code and limp mode only happen when the drivers side turbo is engaged, which happens above a certain RPM threshold.
I was hoping to find someone who had experienced the same problem or who knew what the test plan is for this fault code.
Post #620142 Mon Dec 20 2021 12:22pm
Disco_Mikey
P004C-77 isn't a valid DTC
If the code is P004B-77, then the following is the recommended actions Thumbs Up
Secondary turbocharger charge air shut-off valve system mechanical integrity
Secondary turbocharger charge air shut-off valve system vacuum leakage
Secondary turbocharger charge air shut-off solenoid failure
Post #620143 Mon Dec 20 2021 12:35pm
moonstone
@Disco_Mikey really appreciate your input. What do you mean by it not being a valid DTC?
This is the code being displayed by GAP Tool and is DTC quoted on the initial main dealer report. See below:
Post #620144 Mon Dec 20 2021 1:04pm
Any help ?
Post #620151 Mon Dec 20 2021 8:31pm
Disco_Mikey
Col, my Topix didn't list that fault code Confused
Post #620152 Mon Dec 20 2021 9:04pm
Mikey,
It did come from a L320 list but as it's a 3.0L assumed it probably applies to a L494 as well, but may well have it wrong there, issue date on the page is May 2019.
Post #620153 Mon Dec 20 2021 9:11pm
moonstone
Col wrote:
Any help ?
This is a great help Col. Thank you. Gives my guy a bit more clarity on what to check out. Assume it’s the same engine?
Post #620162 Mon Dec 20 2021 10:39pm
Disco_Mikey
Quote:
The engine control module is unable to command a motor, solenoid or relay, to move a piece of equipment to the commanded position either due to a failure in the actuator or its mechanical environment
Harness failure - Variable geometry turbine vane actuator control circuit short circuit to ground, high resistance, open circuit
Harness failure - Variable geometry turbocharger sensor circuit, short circuit to ground, high resistance, open circuit
Mechanical failure on actuator mechanism
Variable geometry turbine vane actuator control unit failure
Found it this time Confused
Was it a new or recon turbo fitted?
Post #620163 Mon Dec 20 2021 10:51pm
moonstone
Thanks very much to you both for helping me out.
So dealer checked the wiring and found no faults before specifying a new turbo was required. Original turbo and actuator assembly was reconditioned and tested by a specialist (The Turbo Guy in Glasgow) before being fitted by the indy (could have been a different turbo that was already recon’d and sitting on a shelf but not sure what difference that would make) Then he replaced a solenoid that had some evidence of oil contamination in the vacuum pipes.
Pipe work has all been smoke tested for leaks and none found. Im severely out of my depth here technically but is the “actuator control unit” something separate from the actuator and solenoid themselves?
Originally there were two fault codes. The one shown above along with the following:
P2263-22 (EC) Turbo/supercharge boost
system performance - General signal
failure - signal amplitude>maximum
This one is now gone after the replacement turbo was refitted. Warranty Co (RAC) doesn’t cover a brand new turbo hence the recon. Obviously, the replacement turbo being duff is something we’ve considered but hoping to exclude everything else before investigating that.
Post #620166 Mon Dec 20 2021 11:04pm
As the control module has a stepper motor in it, I was just wondering if it needs calibrating in some way if it has been replaced, I think Disco-Mikey may be the person most able to answer that though.
Post #620167 Mon Dec 20 2021 11:26pm
Disco_Mikey
Everything points towards a faulty actuator...
Being a recon unit, and having had issues in the past with duff recons, this is where I'd start
That said, there is a calibration procedure for fitting a new actuator/turbo
Post #620168 Tue Dec 21 2021 5:03am
moonstone
Ok. No calibration procedure has been carried out on the car. The mechanic mentioned that there might be one but if so he needs to find out what it is. Is the calibration procedure something that’s done on the bench? If so I believe that the Turbo Guy is supposed to have done all this.
Is it likely that the fault code above would be present with (an otherwise fine) but uncalibrated turbo installed or do you reckon that the most likely cause is that the new reconditioned turbo still has a faulty actuator unit attached to it and we might be chasing ghosts?
Post #620170 Tue Dec 21 2021 6:41am
Disco_Mikey
Calibration is done via diag, with the unit fitted to the car
Start there before chasing further Thumbs Up
Post #620171 Tue Dec 21 2021 6:53am
