![]() | Home > Maintenance & Modifications > Passenger seat belt warning light - should it work? |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 71 ![]() ![]() ![]() |
Don't know if this is expected, but if someone is on the passenger seat there
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
On my 2005 there is a light for the passenger seatbelt which activates when there is someone on the seat (with an audible alert) and goes out once the seatbelt is fastened.
Any idea on how I unset it? - IID tool?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
The actual sensor is stuck to the foam seat cushion, to get to it you would need to remove the leather seat cover the same as if you were going to renew the heated seat element as it's actually stuck under that. If you look under the rear of the seat from the rear passengers footwell you will see the wiring for it clipped to the seat base, might be worth checking the electrical connections there.
Hi Col,
Hi, I did mislead you a little bit there it was a little while ago I changed one, meant to say check the wiring for damage where it comes through the metal seat pan, the actual connector is at the front of the seat.
Ah ok I'll check at the front |
