Home > Maintenance & Modifications > Passenger seat belt warning light - should it work?
cassman
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Don't know if this is expected, but if someone is on the passenger seat there
is no seat belt warning light on the dash.
It works for the drivers seat, just not the passenger.
Is this really normal?
Thanks! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Sadly gone - 2013 L320 3.0 TD in grey! sometimes towing a Buccaneer Cruiser.
Post #620002 Wed Dec 15 2021 12:47pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
On my 2005 there is a light for the passenger seatbelt which activates when there is someone on the seat (with an audible alert) and goes out once the seatbelt is fastened.
I think either yours is not working at all, or maybe it can be changed in settings? Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #620004 Wed Dec 15 2021 2:45pm
It is possible to set the system to not illuminate the light when a load is applied to the passenger seat. Sounds like yours has been so set. Or the occupancy sensor is broken / disconnected under the seat. 2012 SDV6 - it's missing a couple of cylinders
Post #620019 Wed Dec 15 2021 8:26pm
cassman
Any idea on how I unset it? - IID tool?
Or indeed where the sensor is?
thanks! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #620064 Fri Dec 17 2021 10:38am
The actual sensor is stuck to the foam seat cushion, to get to it you would need to remove the leather seat cover the same as if you were going to renew the heated seat element as it's actually stuck under that. If you look under the rear of the seat from the rear passengers footwell you will see the wiring for it clipped to the seat base, might be worth checking the electrical connections there.
Post #620066 Fri Dec 17 2021 10:59am
cassman
Hi Col,
Ace - I'll do that. check the continuity and indeed if its even plugged in! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #620067 Fri Dec 17 2021 11:19am
Hi, I did mislead you a little bit there it was a little while ago I changed one, meant to say check the wiring for damage where it comes through the metal seat pan, the actual connector is at the front of the seat.
Post #620068 Fri Dec 17 2021 11:35am
cassman
Ah ok I'll check at the front Smile
thanks for the image. Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Post #620074 Fri Dec 17 2021 3:11pm
