Home > General > Window switch - problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. Drivers window switch not always working. If I don't do something about it one day its going to get stuck in the open position. Will the small bank of 4 switches on the drivers door prise up and out without any problem so I can check the connections? Or do I need to look elsewhere? Andrew Kennedy
Post #619663 Thu Dec 02 2021 10:01am
garrycol
Australia
The electrics will be OK - it will be the lever itself - where it pivotts it breaks hence why it works sometimes - if the lever is in the right position it works, if it is not the switch will not work - it is the mechanics of the switch.
In the 11 years I have owned my car I have been through two switch panels - source from a breaker is cheaper but check they are ok as they could already broken.
The issue comes about because you can put your finger under the switch and pull up - too much strength and it breaks. I have told myself to stop doing this and just gently use my finger tip to raise the window. Its been a while but if you are careful you can prise the switch panel out of the door but the wires are a bit short. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #619666 Thu Dec 02 2021 11:51am
I think its more a case of having to remove the trim panel first, to disconnect switches.
Seamed that way to me annoyingly
Post #619668 Thu Dec 02 2021 12:11pm
andrew kennedy
Thanks for the advice. Might try to take the switch out perhaps order a replacement first? Andrew Kennedy
Post #619669 Thu Dec 02 2021 1:50pm
andrew kennedy
A question re my need for a replacement of the bank of 4 window switches. ITS AN EXPENSIVE ITEM and from what you tell me probable not worth buying second hand. When I take the car in for a service next time (very good local guy) would you consider the switch mechanise reparable???! Andrew Kennedy
Post #619714 Fri Dec 03 2021 5:01pm
andrew kennedy
I'm being quoted £99.01 for a new replacement to the window switches on the driver door!!!! I understand from your remarks that the switch mechanism is quite delicate. If I go for a used second hand one, just looking at it, would it be obvious its going to be in good order? I would imagine its a sealed unit?!? Andrew Kennedy
Post #619725 Sat Dec 04 2021 8:44am
garrycol
Australia
I have not bought new replacements - always second hand - just make sure the plastic hinges are not broken.
Of course with yours, it may have another issue. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #619728 Sat Dec 04 2021 10:45am
If you buy online, from eBay. You should get a refund if it doesn’t work
Post #619747 Sat Dec 04 2021 7:07pm
