![]() | Home > Technical > Smoke From Offside Wheel Arch |
Iomegas Member Since: 15 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Hi is this not just your FBH cutting in ? |
Darren Anthony Member Since: 08 Mar 2019 Location: Birmingham Posts: 30 ![]() ![]() ![]() |
I had read about the heater, but I'm led to believe that is on the passenger side. 2010 RRS 3.0 TDV6 HSE
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 951 ![]() ![]() ![]() |
I know that the TDV8 has the FBH on the nearside wheel arch,, and vents to the same side. I think the 3.0 V6 engine has the heater on the drivers side,, and I'm guessing it will vent to that side also. 2010 RRS, TDV8
Just popped out and took a pic. FBH is on the passenger side on mine.
Ah well,,,, thats one theory we don't need to worry about.! 2010 RRS, TDV8
Yeah. Although I can't decide if that's good or bad |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
On completion of your journey, carefully touch the centre of the wheel near to the brake disc. If it's really hot compared to the rest it may be a sticking or seized caliper. If it is it needs sorting quickly or your disc will warp. |
Will check that tomorrow.
Well, an update... kind of.
The exhaust points towards the drivers side.
This was only from the drivers wheel arch though. Nowhere else. Also had a smell of brake fluid to it. 2010 RRS 3.0 TDV6 HSE 1992 Mazda RX7 FD3S |
I didn't think brake fluid had a smell.
