Home > Technical > Smoke From Offside Wheel Arch
Darren Anthony
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Driving home this evening and I noticed whenever I was coming to a standstill there was some smoke coming from the drivers side wheel arch.
Pulled up at home and got out to look. Kept engine running, first few seconds there was nothing then it started to appear again. But can't actually tell where it is coming from.
Aslo noticed a slite humming sound at idle, too. Not sure if that is related, but I don't think that was there till now either.
I read about smoke from the passenger wheel arch being some sort of heater, but this is on the opposite side.
Any ideas???? 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #619496 Thu Nov 25 2021 5:13pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi is this not just your FBH cutting in ?
Post #619499 Thu Nov 25 2021 5:50pm
Darren Anthony
I had read about the heater, but I'm led to believe that is on the passenger side. 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #619500 Thu Nov 25 2021 5:51pm
gogsy1956
I know that the TDV8 has the FBH on the nearside wheel arch,, and vents to the same side. I think the 3.0 V6 engine has the heater on the drivers side,, and I'm guessing it will vent to that side also. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #619503 Thu Nov 25 2021 6:29pm
Darren Anthony
Just popped out and took a pic. FBH is on the passenger side on mine.
1992 Mazda RX7 FD3S
Post #619504 Thu Nov 25 2021 6:42pm
gogsy1956
Ah well,,,, thats one theory we don't need to worry about.! 2010 RRS, TDV8
22" overfinch
Post #619505 Thu Nov 25 2021 7:04pm
Darren Anthony
Yeah. Although I can't decide if that's good or bad Shocked Laughing 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #619506 Thu Nov 25 2021 7:12pm
Oldandconfused
On completion of your journey, carefully touch the centre of the wheel near to the brake disc. If it's really hot compared to the rest it may be a sticking or seized caliper. If it is it needs sorting quickly or your disc will warp.
Post #619507 Thu Nov 25 2021 7:17pm
Darren Anthony
Will check that tomorrow.
Now you mention brakes, the smell was very similar to brake fluid, too. 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #619508 Thu Nov 25 2021 8:01pm
Darren Anthony
Well, an update... kind of.
Got it booked in to a local garage.
They checked everything out and said there was no problem at all with the brakes and everything is moving freely. They tested the brakes where they do MOTs. And also took it out to see if anything happens, too, as well as getting it on a ramp to have a look.
It also didn't smoke or anything since that 1 time on Thursday night.
So I guess it is now just a case of seeing if it happens again. 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #619620 Mon Nov 29 2021 5:57pm
The exhaust points towards the drivers side.
So it blows under the front of the car when still
Post #619626 Mon Nov 29 2021 9:01pm
Darren Anthony
This was only from the drivers wheel arch though. Nowhere else.
Also had a smell of brake fluid to it. 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #619627 Mon Nov 29 2021 11:49pm
riverblanche
not sure if you can do a test run from the IID (would expect so) as I used the webasto software
but raise it up into offroad mode and run it if you can then watch underneath and smell to see if its the same,
the exhaust IS on the n/s but can blow and drift under all the car, some vid you can not even see the car Laughing
also if you get the symptom again check the exit of the fbh exhaust (carefully!) to see if its even running again to rule it out.
potentially brakes or fuel leak anything wet under the bonnet Shocked
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #619640 Tue Nov 30 2021 5:57pm
I didn't think brake fluid had a smell.
The heater exhaust has a smell though. Paraffin or kerosene like
Post #619648 Tue Nov 30 2021 8:21pm
